On the stock browser there is an option to force it not to go to the mobile version of a website. Is there an option on dolphin to do this? Currently when I go to facebook it takes me to the touch facebook site.
I've downloaded an add on that lets you switch between android and desktop. Whenever I switch to desktop it always stays in that mode so would be worth DL that.
Its called desktop toggles and you can get it by pressing the little jigsaw piece within Dolphin or from the market
I don't generally add too many cos they take up space but I have got Fullscreen for Froyo and screen cut which means you can save pics and text from webpages.
there is also a speed one which I've not tried yet as read conflicting reports as it closes apps and acts like a task killer.
I only use 3. The two talked about up ^^^ there and Dolphin Reader. I rarely use it but if a page has a lot of ads I keep touching I flip it on to get them out of the way.
instead of using an add on, go into the settings in Dolphin HD and select User Agent and change this to Desktop. This always ensures you have full page not mobile sites.
