mrgigabyte
Member
hi since i have had gingerbread my quick exit froyo + does not work right when i use it everything is right until the end of it, it saids that it needs to close instead of the app that you really what to force close , i like it because some apps dont need to be running all a time does anyone know of a good replacement that works on gingerbread until they update quick exit
thanks
thanks
