Root Quick Q
PARick
Member
I Just installed a new theme (Live Wire) for my Lithium Mod Rom. Don't know if there is a connection, but when I need to update an app, I get the message something like "process android media process stopped unexpectedly" and it will not allow the update. Everything else works well. I have turned it off for awhile, and have done a battery pull. Any suggestions?
Update-I cleared the cache and data in the Market App, and still can't update.
If you didn't do a complete wipe before you installed the rom this could be causing some issue. It also might just be something inherent with the theme having a bug that hasn't been discovered or resolved yet. Outside of that I'm sorry to say I don't know what to tell you. Good luck.
