I am using ctmod nemesis. But I got a new launcher from the market. While using this new launcher will it affect the root or any of the scripts ive done? And should I delete the old launcher? If so how do I do that?
you can use the new laucher with no problems, you dont have to remove the old they will both be there and you can change which one you use if you want.
You could get rid of the existing launcher if you wanted and just use the new launcher in its place.You could use a market app called titanium backup,they have a free version but id suggest the paid version. you would deff want to make a backup with CWM.. make a backup of the old launcher using titanium backup..convert the new launcher to a system app..convert the old launcher to a data/user app..and you should be sett..if anything were to go wrong youd have a backup of the original launcher..and even more important a backup with CWM..just be careful when using tb to convert apps..sometimes it may be tempermental..or if you wanted to keep it simple you could just keep both like optimus said.
