Root Quick question on flashing
SpartanJ59
Ok so, I have a question on this, how may i make a backup of my current phone to the state it is in so i can flash back at any time?
Use the lte 2nd init recovery app which is your clockworkmod recovery to make a backup.
It will backup your phone exactly as it is now.
I haven't been able to get the touch one to work for me.
So all I can recommend is to restore your backup then see if someone can help you get it working or you might have to use the older one like I do.
yeah um...i didnt have an older one from the last recovery, kinda forgot to but anyway i cant get it to boot back! D; ****
what i had to do is put a rom on my sd card. and flash it to get out of recovery. seem if you install the touch recovery after already having the nontouch recovery. it will keep booting back into the recovery.
wait...i can do that, just flash a rom?
Ok guys i wanted to ask, i just unbricked right and well after i did everything my phone still has all of my apps? O.o and still sais MIUI
You don't have to do it if you don't want. I do it because sammyz says it's easier to root afterwards.
I guess it depends I've been trying to root for the past hour with no luck even though I did factory reset after unbrick.
mine rooted right away actually
I don't know what it is with my phone. Sometimes it will root on first try and other times it's a pain in the a$$. :(
edit: woohoo just got it. back in biz lol
I think I got lucky my phone does everything one try...including brick lol and by the way if i do a factory reset is the the old recovery still on here?
If you do factory reset after unbrick, it removes everything including recovery and returns phone to factory.
