Root quick question
adf527
Can the v6 turbocharger script be run on the connect.and are there any other scrips that can be run on this.starting to get bored flashing this and bricking that lol.can get expensive, but on the different phones i have,the scripts i don't have a whloe lot of experience at.thanks
ehhh yes but no.. would need to modify it 'some' before putting it on the connect.. not sure what benefit it would have though... i have a single proccessor esteem and dont need that... what are you trying to do play xbox games or something?? LOL
Nah i just like learning new stuff and tricking out these has became basically all i end up doing.really is no 'point' other than something new to try.I've already learned the hard way that some things are probably not meant to be changed on the phones without some kinda knowledge as to what I'm doin.so figured id ask,and prolly good i did
