Root quick question
Uriel707
okay say im on stock odex/deodexed rom. can i still get the updates from virgin mobile from settings & still update them or will the rom not let me?
When I was having issues receiving the notification to download I switched to the stock rom and did an update check. I got it and downloaded the update but it did not
install correctly. I believe you have to be s-on stock with the stock recovery as well for the update to install. If not, s-off and flash the radio file included in one of the threads regarding the update. That is the route I had to take. The only real change I have seen since the update is no more sms error.
You don't need the update. If you're a S-OFF you can change the radio. That dudes the problems with signal fluctuations
