Quick question
D
Deleted User
Guest
Hi does anyone have a problem with the battery stats as mines shows ive been connecting to wifi all the time which I havent.
Also my battery is strange because soon as its fully charged within a few seconds after unplugging it drops to 99% straight away. Anyone know if thats normal or a faulty battery? :confused:
Which app gives you History details? I'm not sure about the WiFi issue but the battery drop thing has been a known issue since the Galaxy S2 came out. Nothing to worry about.
Thabk you for the reply, yeah the battery history is wierd, not been connected to wifi all day but on that its just a straight line on wifi, thought it might be a bug or some setting I need to do.
Wi-Fi shows the same on mine but I always assumed it was showing how long my Wi-Fi was turned on, not connected.
I suspect I might know what is causing the wifi to show as constantly being on. When you set your phone up and it asked about location settings, did you allow it to use wifi location too even when wifi is "off"?
When I set mine up, I went with that option. I checked my history details and found the solid wifi line. I need to look at this a little more but I suspect that is it. I say I need to play with it more because I did turn on my wifi since walking into work (no cell signal where I work but bountiful wifi) but there was a little while at the beginning where it wasn't that's still blue.
I just my wifi off now, so I'll see for sure soon and report back. If I had to make an educated guess though, I'd say that's it. On the previous screen though, even with wifi on, it's still the lowest draw on my battery. So not much to worry about.
Ok, so after having my wifi turned off for a half hour, I still see wifi as on in my history screen. So I'm hypothesizing that this is the location services using wifi signals from nearby to determine location as I allowed it to upon set up. Also, after turning wifi to "off", wifi doesn't show up as one of the draws on my battery anymore.
