find a theme that reverts you to stock look of your rom. ask the developer.
for example: on fission they put out an 10% basically revert to stock theme. after it is applied it pretty much overwrites any themes previously applied so that they look stock.
go in to your theme and find the lock screen sliders and change them, then apply your stock looking theme with the new sliders to phone.
(if you dont know how to do this, let me know and ill help).
as far as changing a widgets appearance. use a file program to find the .apk and copy it then paste it on your sd card. copy that to your computer and apply the changes you want. uninstall the original application and sign your new one then apply that to your phone.
(if you need help with that, let me know).
