Root Quick sbf question
jdaud
I am currently on the leaked 2.2 kernel. Will I have any issues if I flash 2.2sbf to update kernel/software?
Well, seems I'm stuck in bootloop land after flashing upgraded .sbf. Anyone got any suggestions?
boot into the stock recovery.
power off phone
hold home button and power button
let go of power when you see the M
hold the home till you see the recovery come up
then hit the search button
perform a factory reset
that should get you back. the sbf does not clear data. so that may be why you are stuck.
