Quiet Speaker Solution
FAQ
Not sure if others have tried this but the speakers are pretty quite.
The volume+ app did not help me out very much. So I just installed a basic equalizer app and it works pretty great. Hope this helps someone!
Which equalizer app are u using?
I find that the volume+ app works great as long as you go into settings under sound then music effects and choose Volume+ instead of MusicFX. I then open Volume+ and go into speaker settings. Check Speaker Modifications and Virtual Room Effect and set the volume level to +5 on both. My phone is louder then my TB or Bionic was!
reimerj
Equalizer by SA Labs
I just moved all the bars higher and saved the changes.
I gotta give this a try as Volume+ makes my bluetooth audio quality with my car stereo crappy. Even if I disable "bluetooth" sometimes it tries to "modify" it. No matter what the settings, sound is much better and deeper with no modifications before going into my headunit. I wonder if this Equalizer has a "gain" bar which would explain your good results.
