How to return your Samsung Galaxy Indulge to stock
DO NOT CHECK REPARTITION UNLESS k0nane OR I SAY TO
Why the big red warning? Far too many people have broken their devices by not following these instructions! Search the forums, or drop by IRC - you'll see plenty of examples.
These instructions should fix your semi-bricked or broken phone as long as you can get it into download mode. Make sure you have drivers already installed on your Windows computer before starting. Please read them all the way through and then begin.
Things you will need to restore your phone are below.
BY PERFORMING THESE STEPS ALL DATA ON YOUR PHONE WILL BE WIPED AND IT WILL BE RESTORED TO FACTORY STATE. I ASSUME NO RESPONSIBILITY IF THIS DAMAGES YOUR PHONE OR DOESN'T FIX IT. DO AT YOUR OWN RISK
Download and use this version of Odin 1.61:
ODIN
Tar files needed to flash are in post #3
Set up the software:
Extract the odin-pit.zip
Run Odin3+v1.61.exe
Make auto-reboot box is checked:
Click PIT and select the acs-indulge.pit that you extracted previously.
Click PDA and select the tar you downloaded
Put your phone in Download Mode:
Make sure the USB cord is unplugged
Remove the battery
Reinsert your battery
Hold down the "9" key
While holding the "9" hold down the power button.
The phone should now be displaying a Yellow Triangle with Downloading... (see next post for image of download mode)
Plug the phone into Computer
Under ID:COM, the box should turn yellow and contain the com port. If it doesn't see Troubleshooting at the end.
Odin should now look like this:
Now you should be able to click Start.
Your phone should auto-reboot when finished and should be working 100%!
This has worked on numerous phone that have partition issues, intermittent booting issues, and many other file system issues.
This returns you back to factory stock, aka Metro/Cricket has no idea stock
Troubleshooting:
Odin isn't detecting the phone?!
It seems frozen and hasn't made any progress for 15 minutes
here is a how to video for the epic but its the same basic process just with different files
