offanairplane
So I installed Liquid Smooth 3.2 and have been running it for a while with no issues other than the known ones, and I can live with that.
But lately, when I leave for work in the morning, my phone is on wifi at the house, so about the time I pull out the driveway it gets out of range of the wifi, so it starts looking for 4G, which normally I have a very strong 4G signal at and all around my house. And it will show the 4Glte symbol but in Liquid it's white while it's trying to connect, and then turns blue when connected. It never turns blue, it just stays white, and data doesn't work when it's white.
So I start driving and it never changes, but eventually the 4Glte goes away and there is no data at all. I can put it in airplane mode and take it back out of airplane mode and sometimes it will connect to 3G at that point but most of the time it won't.
But the odd thing is, I can reboot the phone and once it gets booted back up again, it finds the 4G signal (that I knew was there all along) and connects right away and all is fine at that point.
I am not sure if it only does this when I am leaving a wifi connection or if it doesn't it just randomly.
Is this a ROM issue or a Radio issue?
I am not sure which radio comes with Liquid 3.2, but after I flashed the rOM I then flashed the 605.9 stock radio.
Should I flash the 605.5 radio and see if that helps?
Any ideas?
Thanks!
Any ideas?
Thanks!
