jtreadwell
Read through, I promise there is a question at the end.
I rooted the phone yesterday. That was a great success. I have already pulled off all of the junk ware Verizon puts on the phone and its much better already.
I used this method. (Yes I use a Mac)
[Mac Procedure]: How to Root the HTC Thunderbolt - Android Forums at AndroidCentral.com
I then proceeded to download and play with ROMs. (Is it just me or does Rom Manager Suck on the TBolt?) I flashed CM7, Liquid Smooth, and BAMF multiple times. Did resets, cleared cache, Dalvik, everything I could think of.
I finally arrived at the conclusion that I need to flash the Radio to a newer version. I've done some extensive reading on it and I believe I have the downloads I need. I have a download of what appears to be the stock radio the phone has now, (1.16.00.223r) and MR2 build, (1.39.00.0627r) and an MR3 build (1.48.00.906w_1). All obtained here
Radios!
Referenced here from:
[q AND a!]v1.45 Noob starter guide/how-to HERE! (updated 10/14) - xda-developers
I'm going to try the MR2 first, I got the MR3 just incase. All three are on my SD card so I can easily rename if I need to. (Yes MD5s are all good on the downloads)
So I think I have done my research and I'm on the right path. I have even looked up instructions to return to a stock non root state just incase...
[HOWTO] Restore to stock for root users and non-root users UPDATED 5/17/2011 - xda-developers
Or my plan to get the phone swapped if things go really bad is to run over it with my car and walk into a Verizon store claiming to be the victim of an extremely cruel work place prank. (Got to love the TEC insurance)
Finally we arrive at the question. Is there a way I can simply backup the stock radio that is already on the phone? I know the first download mentioned is suppose to be it, but I would feel a little better if I could go back to the one originally installed on the device. I've spent to many years in IT to not be cautious and take every possible precaution. One can never have to many backups or have enough detail in a back-out plan.
Thanks for sticking with me to the end of this epic. Wish me luck.
Radios!
