hate
i'm using CTMod 2.4 and used UOT Kitchen to theme it. I wanted all the signal icons to be circular. After installing the theme i started my phone, all the icons seemed ok but after media scan was done the icon for radio signal started switching between the normal bar type and circle one. i checked framework-res in drawable mdpi. the normal radio signal seems ok the zz radio signal are still bar icons. is this what is causing it? if so can i copy and rename the circle icons to replace the zz ones? i remeber that these didn't need to be changed for froyo themes. any help would be appreciated. and if its needed or just easier i have the zip uploaded. let me know and i'll message a link.
