Root Radio Update..
RunVert
Is updating my radio something I should do periodically? or is it dependant on my current kernel and ROM combo?
I am using myn 2.2 ROM and using Netarchy 4.3.4 kernel.
My current radio is: 2.15.00.11.19
In ROM manager there is a "stock 3.70.651.1 deodexed" radio version available. This appears to be several updates higher than what I currently have. Should I flash this, or some other newer radio? Or stick with my original stock radio?
thanks!
thanks!
That is the current official release radio and software base version so you are good to go for the time being.
