Root Radio with JagerROM
tranzue
Hey all,
I just recently purchased ROM Manager, and decided to try out downloading a ROM through it. I decided to go with JagerROM, which I've seen before requires the 2.2, but in ROM Manager it didn't say so. So I downloaded the ROM, and it works perfectly, my only question is, how can I tell if it already updated my radio or not?
Under my software information, it says Android version 2.2, but the Baseband version is 1.00.03.04.06. So is my radio already updated?
Thanks for the reply, maybe that explains why the camcorder is the only problem :rolleyes:
So basically if I want it to work, I'd have to go through the whole deal of unrooting and all that, to get camcorder working?
I think I'll just be happy without the camcorder till the actual OTA rolls out
it doesn't require 2.2 to run, it IS 2.2. 2.2 refers to the android software, what is required for jager to work 100% is the radio update which is 2.05.00.06.11, as mentioned by ktan.
BTW, the whole deal of unrooting and rerooting takes less than 10 minutes. just be sure to read the cautions regarding the radio update.
