D
Deleted User
Guest
I just posted the same message on the Galaxy S2X forum which I think is the same version as the T-mobile:
Hi there,
I am just about to buy a new Samsung Galaxy S2x but I am wondering if there are any memory limitations due to the phone or the Android 4.0 OS. I presently own an HTC Desire (Froyo 2.2) with 576 MB of RAM and although I rooted it, I am still having problems installing Apps because the amount of Ram available is too small. I don't have that many Apps installed, maybe 40 or 50 and most of them are quite small in size (less than 1Mb) and have been moved to the SD card, yet I'm still getting low memory messages all the time. If I want to install a new app, I have to remove another one. I know the S2x has 1Gb of Ram but I read a review on mobilesyrup that states that the S2x actually uses around 3/4 of that for system use. I am mainly changing phones because of this issue (other issues as well but not as important). Is this app installation limit a peeve of Froyo2.2 which has been adressed with 4.0? Has anyone installed a ton of apps on the S2x without any problems? I do not want to root the phone until the warranty has expired.
Thanks for your help.
Hi there,
