Ran into a problem
Premonition
for about 30min now my 3G isnt receiving data, its only sending out, for example i go to phone info with the #*#4646 etc number and when i run ping test it says IP addr not reachable. I also go into settings and every few min it would say mobile network connected then it goes off and tries to reconnect again.
Has anyone else been through this before? and do you think its a sprint situation more than a phone problem?
I hope this doesnt happen again, i had to take out the battery for a while then put it back in and start it back up.
it seems like my problem is with the Advanced Task killer, everytime i kill all the apps it takes out the internet. which is wierd because it never did it before
If task killer is causing a problem, you will probably have to do a hard reset to fix it. Uninstalling the app isn't enough occasionally.
I was having the same issue. I flashed the newest radio and 3G seems to be working okay now. Having issues downloading from the market though, it just sits there with an empty progress bar forever.
*edit*
Market downloads are working for me now.
