I'm getting a little annoyed at how easy it is to cause problems with the SD card on the DHD.
I've just unmounted the card, forgot I'd done that and put the USB charger in. Then remembered and mounted the card and it's gone from fine to saying it's damaged.
At the moment I don't have an adapter, so can't plug it into the PC to check.
This is the second time in as many days that the phone has said the card is damaged.
I really didn't want to reformat after transferring a load of music to it, moving all my apps to the card as well as creating ringtones, alarm and notification sounds.
Any ideas what causes it... unmounting and mounting can't be enough... and plugging in the USB charger (set to charge only) shouldn't cause this kind of issue.
