My prevail sometimes does a notification sound without any actual notification. Last night was doing it every 30-45 mins while I was sleeping; sometimes they work on towers overnight so it could be from that. From some Googling it might be the roaming notification sound. In most phones it can be turned off at:
Menu/ Settings/ Wireless controls/ Mobile network settings/ Data roaming
the prevail does not show this setting.
Anyone has problems with random notification sounds? Any way to get to that setting? I tried searching far and wide but couldn't find anything, I even tried "any cut" but no luck.
My phone is rooted, if that helps.
Thanks,
Haris
Thanks,
Haris
