Help Random reboot causing extreme battery drain?
EVU
I am having random reboots on my EVO4G & concurrently causing the battery to drain to zero.
Subsequently, it forces me to plug in the phone to recharge to actually get it rebooted & turned-on.
Stock & NOT rooted.
First time, anything of this magnitude has happen.
Not sure what is going ?:confused:
Stock & NOT rooted.
Have you downloaded anything recently and then noticed this issue?
How old is your battery?
  • Like
Reactions: EVU
You are correct - it was the battery.
Replaced the 2 year old OEM battery with a new one.
Everything is okay again.
Guess I must've have killed the old one having it constantly plugged in @ work & used up all the possible charges on the HTC supplied Li-Ion.
Thanks for chiming in.
Awesome, a simple fix for once! :):D :p
