Root Random rebooting after rooting
madAdam
Phone is running fine after rooting and deleting a few unneeded apps but about once a day it reboots randomly. Anyone else?
What apps did you delete?
Amazon, Blockbuster and CityID. I deleted these with Titanium Backup.
First time I noticed a random reboot was while installing the New York Times app from the Market. Phone rebooted during installation and then again when I was configuring the New York Times widget. That app has worked fine since and reboots have been apparently random.
If you haven't already done it, turn the phone off, remove battery, wait a minute then reinstall the battery and turn it back on. See if that helps at all, it's worth a try.
3 times in the past 3 hours, randomly.... I"ve rebooted (pulled battery) multiple times over the past few days.
I might unroot and see if it continues.
Had this issue myself today. Worse. My phone didn't charge last night, even though it was plugged in. Soon as I took it off the charger the phone rebooted and I had 40% battery to start the day. :/
I backed up and then removed pretty much the same apps you guys did btw.
Mine randomly rebooted today. When it came back on, its like it had performed a system recovery, and reset to two days ago. Some apps I had installed were missing, and all of my messages from the past 2 days were gone. I have also removed amazon, blockbuster, city id, and some other programs.
I've had 1 reboot each day for the last 3 days. Not sure why, no apps removed, I had the same problem with my Inc, must be something to do with VZW.
i have same problem here did anyone do the one click root? thats what i used
I used the one-click root...Everytime I opened the tool-mode for the widget locker i realized that my phone rebooted. I deactivated it and now it hasn't restarted (crossing fingers)
I have not uninstalled/deleted any system apps, and I am also experiencing the random reboots. Not annoying, just worried something is wrong with my phone. Yes, I'm rooted as well.
I've been having the same problem. My list of uninstalled apps is a bit longer that just CityID, Blockbuster, and Amazon MP3. Is anyone else running Launcher Pro?
I'm using Launcher Pro, as well as Executive Assistant. I agree that it's possible our random reboots are a result of third party apps we have installed.
