Since upgrading to 4.0.3, (XXLPQ) My phone (i9100)randomly reboots by itself
I will look down and it will be on the Samsung screen booting back up
Anyone else experiencing this?
Hi ive had this problem re booting during the night for some reason,since i have flashed checkrom v6 the problem has disappeared,could have been the previous rom perhaps? hope this helps
Although the firmware updates are non-wipe, unfortunately sometimes you have remnants of the files that clashes. It can cause reboots and many have complain when upgrading from 2.3.3 to 2.3.4 etc.
It is recommended you do a wipe (clear cache and factory reset phone) if the problem is serious enough. You do lose everything so you need to backup as much as you can. I had some reboots before when upgraded to 2.3.6 from 2.3.3 but it wasn't all the time, and after some time seems to have resolved itself. So I never had to go down that route....
