Random Reboots
pacothebandit
UGH! Anyone getting this? I have had this phone replaced 3 times. Well i'm on the third one and its getting annoying. What might i try??
I got a few on 4.0.2 but no problems since I've flashed Android revolution HD 3.0.0 which is 4.0.4 with a few tweaks.
Getting the phone replaced isn't going to help the problem... but you've already found that out!
Are you on 4.0.4 yet?
Nah, im not on 4.0.4 yet. But...I may go ahead to root my phone tonight. I did it with my NS4G, i've just been holding out.
Same. Got one every couple of weeks on stock 4.0.2. Now on AOKP v29/Franco M2 and not had one in weeks
I haven't had a single random reboot since I rooted again last week. I had un-rooted a couple of months ago, and was getting sometimes multiple random reboots every day.
My friend has the Verizon Nexus and stated his reboots were due to overheating. I forgot the details of what he was doing to heat up the phone, but when your phone reboots, check to see if the phone is really warm right when it reboots.
I started suffering from the odd reboot when I started playing games on my phone, particularly Angry Birds and Drag Racing. I've found that rather than exiting by using the home screen soft key, leaving the app open in the background, if I exit the apps properly (back out to the main screen and exit) I don't have an issue with the reboots anymore.
I have also been having problems with reboots on my Galaxy Nexus. Most common issue has been while trying to track cycling routes using appropriate apps. App makers have no record of similar issues, although they also do not have much testing on ICS.
My current supposition (as it has occurred with multiple apps now) is a heat issue. I am thinking that the combination of silicone case, plastic bag, and body heat are the cause. Next ride I will try without the case and see if it helps (or maybe hurts!).
Any other thoughts/ideas?
I get random reboots all the time ... in fact, it just did it a few minutes ago while I was sitting here at my desk.
I mainly get them when I'm using Skydroid on the golf course - and it's incredibly annoying when I pull it out to check a distance and the app needs to be restarted & GPS has to reacquire my location ( it takes a while sometimes ).
I'm also using Nova Launcher.
Hope this is addressed in the 4.0.4/5 update when ... and if ... it eventually comes to Verizon.
Im on the GSM GNex 4.0.4 stock google rom - I only get random reboots when I use 3rd party batteries. Only happened twice so Im not complaining. Are you using 3rd party batteries?
Over the past month I too started getting a lot of random reboots, 2-3 per day. but one thing that has helped is uninstalling all the google+ app updates.
after i uninstalled the updates i lasted 24 hours without a reboot. finally had one this morning. now i disabled the google+ app completely to see if that helps further.
i got this idea by looking at my wife's gnex, which has an uptime of over 400 hours. she doesn't bother updating any of her apps and i noticed that google+ was still on the original version.
my phone still crashes when browsing, which is more annoying, but the reboots when i'm not using the phone seem to be less frequent.
