Help Random vibrating and force closes after 2.2
Robodr0id
I updated to 2.2 last night, and my phone was unusable. It wouldn't connect to the network, it would randomly vibe and FC, and stuff just wouldn't open. I did the "fix froyo" trick (resetting to factory), and as I was reinstalling my apps I started getting random vibrating and FCs again. Any ideas how to fix this? I'm thinking about re-rooting and getting a custom ROM but I can't find any that are just the default Samsung GUI and 3.0.
Thanks !
Edit: now I can't even open the market. It force closes after a few seconds of trying to load.
Im having the same problem and havent figured anything out. My hubby has his phone rooted and hasnt had any problems. Id love to do it to mine too but if something happens to the phones we cant afford to replace 2!
Good to see someone else has this problem (I guess). I also noticed that some apps will open fine, and Movies just gives a FC.
Has anyone found a fix for this yet? I am having the same problem. I go to the market (both through LauncherPro and Go Launcher EX) and get this fast 3 vibration thing and then the market force closes with a warning screen popping up saying: "Sorry! The application Market (process com.android.vending) has stopped unexpectedly. Please try again." Trying again produces the same result.
I am rooted with Evil Fascination if that helps.
Firmware 2.2.1
Baseband version: S:i500.04 V.ED01
Kernel version: 2.6.32.9
Build number SCH-I1500.ED01
Thanks!
