check out my post on prepaidandroids.net when u use windows download after the phone is rooted you have to copy paste superuser to sd card then run the program. user easy is not a self ex. file. hope this helps please let me know. RANGERS LEAD THE WAY!!!
I got errors like some are describing in the other topic on rooting the admire. I already had superuser on my SD card and installed it after verifying root access with rootchecker.
Everything is fine. I think the exploit reports that error because it cant install superuser as part of the "one click" unlocking process. Doesnt really matter... IF the exploit reports "enjoy your rooted phone" then you should have root access and can begin doing what you like with the phone.
