Help Rattling as typing
micahdiablo
I have haptic feedback as I type but I notice that as it types and vibrates it makes a slight rattling sound with it?
Anyway to fix that?
Does it make a rattling noise at any other time (vibrating or not), such as when you receive a call, notification, or shake the phone when playing games?
Kratos
Seems like any vibration. My old Incredible 2 was horrible, and i never noticed it until i got a new warranted replacement. Which has started it as well. Just tapping the home button would sound awful.
My DInc2 doesn't make any noises except for when the vibrator is very strong, which is really only when I play Coin Dozer or get a phone call. And even then, it sounds like a vibrator and nothing else.
Have you removed the back and looked for any loose components? Not much back there, but you probably don't want to void any warranties by tearing the whole thing apart...
Also, do you notice the noise when shaking the phone? If you haven't tried, just shake the phone back and forth a little and see if you can hear anything rattling...
Kratos
Kratos
No I have only noticed it as I type on this phone. It rattles at the bottom it sounds like. I'm not sure why.
