hey everyone...just deciding to post my solution for the fact that the razr m does not have a charging desktop dock..
Solution #1: buy this
Amazon.com: Cellet 267691 Universal Cradle Charger for HTC Smart Phones - Retail Packaging - Black: Cell Phones & Accessories
then when you get it youll notice the usb connection points your phone away from you....take a small screwdriver and pop off the bottom piece "glue holds it on one end" around the connector...flip the usb around....and put it back together gluing the pice back on the cradle...the usb part slides in and out a bit so you can zero in the best place for it
then go into smart actions and create an action to launch an app while powering (not docked)....theres plenty of apps in the app store but i used the regular clock app because it has root access and will work even when you have a password lock on your screen
it works well but its not so smooth where you can simply plop your phone down....you gotta do a little lining up of the usb on both the phone and dock...but once the phone is it it works fine....no audio but bluetooth though
solution#2" buy the smart charging dock (on ebay if possible)....i just use the cable that comes with it (it activates moto dock mode) and since its angled you can actually just plug your phone in and rest it on its own wire...the phone will lean at an angle and there will be no need to use the plastic stand that comes with it....this feature will not requie you to use the smart action as the cable already puts your phone in dock mode
well there it is...neither is clean but thats all i got....thanks!
