Many questions re: Razr - so here's an attempt at answering some of them
1) There is a hardware button push combination that simulates a "battery pull" on the device. No need to worry about getting stuck in a situation where you can't force the hard reboot.
2) THIS was the device I was referring to a while back as being VZW's key product. It's also a droid branded product, so it gets the extra VZW push and marketing spend.
3) Bootloaders - i think this question has been beaten to death already.
4) The battery life isn't compromised by the phone size. It's still a large battery. I wouldn't recommend pulling it out to try to tinker with it. Motorola will have a solution for extended battery lovers down the road as well.
5) This will be the last touchscreen only droid you'll see this year, so no need to worry about a new one coming out in the next few months.
6) Release date - earlier than you think. (Nov 3rd you ask? Hmm, I say)
