Root razrs edge not working?
HotPepper
So i have usb debugging on. Phone connected
When i click run and press enter it just says waiting for device and stays at that. Whats going on?
Im on a replacement phone from verizon my old bionic didnt have this problem
I'm on windows XP. The same thing happened to me. I had to uninstall the 5.6 moto drivers and install the updated 5.9 moto drivers.
Besides having USB Debugging enabled, make sure that your USB connection type is set to Mass Storage. Also, did your replacement Bionic come with ICS pre-installed, or Gingerbread? Mine came today and had GB. I used RSDLite to flash .246 and Raz'rs Edge worked flawlessly for me.
After RSDLite flash of ICS stock image, razrs edge one click root tool worked flawlessly... computer is windows 7 though. Had to install moto usb drivers as well.
