A
Android Question
Guest
Can not get some apps to work on the tablet....ex: WWE.com and Bingo Blitz from FB.
You want to ask op did they check that unknown source box in the settings . my mother has it got mad wanted to tell Santa a few words cause she was pissed but hey got it working and she say thank yDo you mean won't install or will install but then won't run? Do you get any error messages?
u to sant
You want to ask op did they check that unknown source box in the settings . my mother has it got mad wanted to tell Santa a few words cause she was pissed but hey got it working and she say thank yu to sant
Do you have Google play servicesYes, we checked the Unknown Sources box....not capable with the device....won't show up in Google Play App Store...
How about use the browser and select play store if it pops up if not just installWhen I typed in WWE(WWE Network App), it does not show up in the Google Play Store....is there something I am missing regarding comparability or is it too new to get it?
If what you want to install is not compatible with your tablet there's probably not much you can do. Even if you manage to get the app .apk file somehow and try sideloading it as from an unknown source it's likely it either still will not install or fail to run even if it appears to install. IOW the simple answer is to stick to compatible software.
