Help re-booting problems!
OMG my desire wont boot up right!! it shows the white screen and htc but it just stays there and i cant get into the HBOOT to reboot i always have to remove the battery to kill it. any help?? plus the phones hot should i just fully let it charged while it is off??:eek:
Had the same problem. Phone would go into a "reboot loop" randomly. It's better to send it for repairs if your under warranty. You could try and change the sd card and see if it helps.
