Help re flash ICS?
ckar
A few days ago my phone had an unfortunate meeting with my pool. Since then I dried it with rice, etc. Everything is running perfectly except the camera. Sometimes it works, and sometimes it doesn't! I've done a factory reset, which hasn't seemed to help. I was thinking about reinstalling ICS. Is this even possible, and if so, is it worth the time? I just want to exhaust all of the possibilities. Thanks for any ideas.
i believe it will be a waste of time. the camera hardware might have become fried.
try downloading another camera app and see what it will do. all in all if you want your camera back you may have to file an insurance claim.
I agree with VS unfortunately. Getting wet should have had no effect on ICS. It sounds much more like a hardware situation. A quick DL of another camera app should confirm our fear. On the other hand.. being as it works sometimes and not others, there is always the hope that it will eventually start working all the time.
One can always hope.
