Root Re-flashing kernal for Fresh 3.2
Wile-E
I have been using Fresh 3.2 but have been playing around with other kernels (ie Toast, King, etc.). I want to return to the new kernel in Fresh 3.2 but can't seem to find it (I only want to flash the kernel so I don't have to do a complete wipe). Flipz says to use the Fresh Updater, but I see no options for kernel only. Any suggestions?
Actually, if you do go to the Fresh Updater - it is listed. Have you set up the servers for the themes portion? If not, go to Fresh Updater > press menu > config > theme update settings > manage theme servers > press menu > update featured servers
VOILA! When you go back to the main Fresh Updater page and click tweaks - update and then there will be a drop down bar which you can download any of the items and install. All downloaded objects are placed in the Download folder on the SD card.
