Re-Installing 2.0
botts121
I was wondering if anyone knew where to get Android firmware 2.0 and how to re-install or re-flash the droid.
I'm having problems with my firmware and I wanted to re-do my Droids firmware back to 2.0.
Thanks in advance.
I'm thinking only Verizon can do that for you. If a 2.0.0 update.zip file was available, I'd think one could download it from Sholes . . . but no such luck.
Yea i just wondered about this. I will check that site out though...thanks. But here is my problem, certain keys on the physical keyboard dont work now but worked when i set up my email and activated my phone after a hard reset. And my volume rocker and camera button dont work either. So given the fact that they work when i activated my phone but not now, Im thinking it is a software problem.
But anyways thanks.
If anyone else has any advice, I will appreciate it.
Thanks in advance.
