Root Re-root for recovery partition?
Fathawk
Hi all,
I am pretty sure I have root, as if I open emulator and SU It goes $ to #. I am running build "2.19.605.1 CL123435 test_keys" and everything seems stable. It's funny that I'm running 2.1 because I never flashed the ROM, I couldn't get past recovery partition set-up.
When I try to press power+up volume all I get is the yellow triangle exclamation point with the android cartoon. This is where I stopped on my first attempt. When I powered the phone back up, it's running 2.1.
Can I re-download the recovery partition .zips and re-flash the root ROM to start all over? I'm thinking my DL's of some of the recovery images may have been corrupted. I'm thinking since I have root, re-flashing the root ROM shouldn't hurt anything right?
Kinda green here, it took me a long time to realize why there a bunch of different files with the same name, but not the same contents (pmb). I'm assuming that's the only filename that the boot loader will recognize.:o
Well since you are already rooted all you need to do is just put the recovery back on the phone and then do a data and cache wipe and reflash whatever rom you want
the rooted rom is just 2.1 with developer permissions so since you rooted you got 2.1.
If you can't get a recovery on go into the irc irc.thefuzz4.net #erisroothelp
There might be another way to get recovery on there, but this may be a long shot.
Download ROM MANAGER and then try flashing the recovery from inside the app, I say this is a long shot because since you are on the original root rom you don't have SU.apk , but who knows you might not need it. Im just throwing up ideas hoping one helps you out =p
So, I'm having the same problem too, with the droid, and the exclamation point. I have a mac, and I put the recovery flash and the image on my SD card, but cant get it to work. What should I do?
Thanks.
