Root Re rooting Samsung Galaxy Note ICS 4.03
Proper158
Hey Guys,
My phone was working pretty good until the root got broken and I began having major issues updating apps via Google plan. I know the root is broken because I can't use my Six Axis app and SuperSU is broken along with Mobile Odin. I can update some apps manually after doing a hard reset.
I tried re rooting doing a hard reset and installing from SD Card, but it wouldn't see the CMW.zip on the external SD when prompted.
Do you have suggestions on how I would re root my Note ICS 4.03 using PC Odin? I tried downloading: XXLPY 4.0.3 Rooting Package but it's no longer available on Chainfire.EU.
Thanks,
Proper
