I am trying to use a USB SD CARD READER Choked down to a micro USB on my droid razr ics.
I want to download jpg's from a camera sd card.
No file apps recognize the sd card.
Am I attempting the impossible?
unfortunately that will not work as you are finding out. usb devices needs special drivers for most devices to work.
like mikey suggested, put the camera's sd card into the pc and transfer the pics that way then hook the phone up to the pc and transfer pics to it. if you have one of those EyeFi Cards, then it will automatically transfer the pics when it detects your network.
