Help Real problem! Play store accept and buy won't work
When I try to purchase anything from play store the "accept and buy" button won't "press" no matter how ,any times I hit it. The button accept and buy its not normal, it is dark gray on the top and the bottom and the appropriate light gray through the middle... I already tried to fox permissions and there s no change. Any ideas?? Thanks in advance..
Did you accept Google's terms right above accept and buy button I do believe? That's only reason it should be greyed out
Sent From My HTC Evo 3D Using TapaTalk 2
When I click "terms of service" of takes me to a web page that has no check box for agreement
Here's a screen shot:
Look at your screen shot. Look at that little line right above "Terms & Conditions" and below "Accept and Buy". It says "I agree to the Payments for Google Play Terms of Service." That's a check box in front of that line. Tap it to check it. Now you should be able to hit "Accept and Buy".
By the way, is your username a Seinfeld reference?
Thanks on the more detailed instructions
