Got the galaxy. How often do i need to turn this off or restart this device to ensure a long lifespan/optimal performance? Does it matter whether I actually turn it off for a period of time or just restart it? thnx
I restart it at night before it goes on the charger. Killing apps does not seem to always release RAM back to the non active app level.
Android is very efficient with managing memory. The only reason you should need to restart your phone is if:
a. You have excessive battery drain (can be caused by misbehaving app)
b. After you so a system update (if the phone does not restart automatically)
c. If you need it to charge as fast as possible
Aside from that the android OS is pretty robust. A lot of the task-killer apps actually cause more battery drain because apps have to restart themselves. There are legitimate times when task-killers work, but for the most part your internal android task management software can handle everything quite well.
Just my opinion
is there a difference between reboot vs a soft reset?
Mine is also showing about 90% memory usage, with everything closed or killed. I haven't been restarting my phone.
Judging from the name, soft reset could mean it doesn't fully reboot everything idk.
on iphone, rebooting the phone doesn't make a difference. but a soft reset can solve issues.
Memory as in ram? go to your task manager, hold down the home button for a few seconds then tap task manager, go to the setting that I believe says ram manager, then tap restore ram or something idk
If I hold down my home button goes to my Google page thing.
Oh right! You have a Galaxy S5, okay, press the task manager button (it's on the left beside the home button) then press the thing that says task manager and follow the instructions I told you before and you should be all good![]()
Yep on mine I long press the multitasking button and it goes to home screen settings where you can move pages and folders. Etc.
And yes I have an s5. This is an s5 forum.
Don't long press it, just tap it, and press the pie chart! That's what it is! I looked up an image of it lol. (It's in the lower left corner)
Oh okay. See that now. But with only 2 apps running, this being one of them I'm sitting at using 1.4 of a possible 1.8 gb
Press the reduce ram option or whatever... Been a while since I used touch wiz
