Root Really, REAlly, REALLY messed up Contacts!
dkl1
Android Expert
While on my Google account I noticed that I could merge all my fragmented addresses and phone numbers and such so I DID. Then all hell broke loose within my Contacts on my G3. Most of my contacts are just completely jumbled up - for example: one persons contact will have another's phone # while the email will be yet another person's email! So when I am getting an incoming call, my screen may say that it's "BillyBob". Yet when I answer, it may be "BessieSue"! I did the merge on my laptop but all those are seemingly unaffected - just the ones on my G3 are screwed up. Anyone have ANY idea how best to remedy this short of flashing a new rom?
This has nothing to do with flashing a ROM.
I don't know exactly what you did that fouled your contacts up so badly. But to put your Google contacts back the way they were and on the G3, do this:
1. Turn off contacts sync on the G3.
2. Delete all the trashed contacts on the G3. Settings > Apps > All > Contacts storage > Clear cache > Clear data.
3. On a computer or the phone browser, go here. This will restore contacts to any point they were at in the last 30 days. Just pick a day prior to the tragedy:
https://support.Google.com/mail/answer/1069522?hi=en
4. Once contacts are restored, turn contacts sync back on and resync to the G3.
You are healed.
You are healed.
Thanks Crash for your reply and suggestion. It appears to be a good method and is step-by-step. I like that! As I said, all I did was click on a little button that said something to the effect "Click to Merge all contact Info..." and VOILA - my mess! At any rate, I HAD to fix it so I simply restored a known working nandroid backup. All is good except losing some data from the past several days while I was on that newer version ROM. I did NOT want to backup any part of that misery!
