Help Really stupid question
Kamala
Member
I managed to turn off vibrate on dialpad, no idea how. How can I enable it again. Tried absolutely everything. Now I dont if Im crazy, starting to think that there was no vibrate at all. Haha.. btw using latest nightly.
1809 doesnt have that option.
Very odd. Its a standard android option. Are you sure you're using the android "Settings" ?
I think on the nightly, there is a "settings" for the ADW launcher as well. Perhaps, you're mistaking that?
-chronodekar
Just go Dialpad click on menu key, choose "Preferences" then scroll little down until the option "Enable haptic feedback" and go to Cyangenmod/Input settings/Haptic feedback tweaks.
So choose your medicine. :p
Yes, Im sure that there is no option for Vibrate touch dial pad in latest nightly, and yes I enabled all haptic feedback in phone (there is one in Spare Parts also :) ), still no vibrate.
Thank god for restore, vibrate will be back after it.
And thank you guys for your time. Like I said it was stupid problem.
