Help Really weird problem with micro usb
stevis
the only micro usb cables that will work with it are an old samsung wall charger and my mom's new samsung usb cable. everything else will either stop working after a half second or not at all. Even the cable that came with my phone stopped working after a few months.
i'm trying to trade cables with my mom so i can plug my phone into my pc but that only avoids the problem instead of addressing and possibly fixing it.
my first thought was a bad micro port but if that was the case i'd imagine no cables would work.
it's not a terribly pressing issue as i'm still capable of charging but it's preventing me from nerding out with custom roms and all that.
thanks for any help offered!
edit: i've tried manipulating the seemingly bad cords like holding them in different directions, resting the phone in certain ways, but nope.
That is weird. I have seen weird behavior similar to this with my daughters nook color as well... I would see about getting an actually moto replacement cord and see if that works.... phone is less than a year old by any chance is it?
The Triumph hasn't even been out a year...
I would contact VM and get a replacement from them... Others have problems with it not accepting other cables, but I personally haven't had any problems with mine and other cables... Its probably a problem with internal circuitry to the micro-usb. Just tell VM that your charging port isn't working properly or something like that and they should send you a replacement under the 1 year warranty...
hmm that was something i was hoping to avoid lol
assuming i have Titanium Backup and SMS Backup both with up to date backups, what would i lose on a new phone?
Or what you could do is backup your current recovery then replace it with CMW make a nandroid backup and replace CMW with the original recovery that you backed up, then just do the same on your new phone, but restore your nandroid backup... That will save all your apps, messages, settings, everything. You can follow this guide to do that just reverse the steps when returning it to stock recovery. Hope this helps!
Edit: also you can keep your phone from what I have heard until they send you a new one then you can just send them your old one within like 3 days or something like that... I haven't done it so I don't know exactly...
I know some Triumphs have had issues using cords other than the ones from the OEM. Your issue sounds similar (but obviously different). I would do like others have suggested and call them to get a replacement.
You can put the CWM recovery on the phone and make a nandroid (basically an image of the hard drive) and do the same to restore it. Here is a link to putting the recovery on your phone: http://androidforums.com/triumph-al...stalling-cwm-custom-rom-motorola-triumph.html
Just follow the first part until you do the making a nandroid part and stop. Then replace the recovery.img with the original. You can then put it on the replacement and restore the nandroid. :D
If you just use Titanium you would lose your setting like NA79 said, so it may not be worth messing with that if you are not worried about those settings.
Edit: How did I not see marc12868's post? I must be blind, sorry for repeating most of that info. :o
Lol oh well at least it shows people agree with me :D.
i mean that sounds like a really good idea but once i get to this step
6. Plug the phone into your computer.
i'd be screwed
yup it seems straightforward enough but if have any problems i know where to ask now
thanks for the help guys
i'd be screwed
Well, unless you modded a ton of stuff on your phone it may be just as easy to use the backups you have and just redo your settings.
If you can use the other cord then it may be worth it. Up to you ;).
