I'm looking to rearrange the app icons in the app pages, NOT the home page. Hold and drag only moves them from the app page to the home screen. They are in alphabetical order and I want them in order according to usage.
Is there a way to do this in the phone or is there an app to accomplish this?
The phone has Jelly Bean 4.3 stock as shipped from Motorola direct.
On my LG Motion 4G, I'm using Holo Launcher HD (free version). I liked the LG launcher, but decided I wanted a more stock look to my phone. I played with several and decided to stick with Holo. If you down load one, make it the default and play with it for a while. You can always go into the settings and clear the defaults or just uninstall which ever one your playing with. Just don't ever uninstall the stock 'cause then you don't have one to fall back on if you uninstall the current one your playing with.
