after i installed beats audio mod into poweramp, i get random reboots
For sure a davlik wipe, Also did you make sure to get the cdma version?Please list the rom, s-off or s-on, Hboot version? Did you do a fresh install? etc.For sure a davlik wipe, Also did you make sure to get the cdma version?
s-on, rooted stock, stock hboot, fresh install, did the whipes, yes cdma
Does not work on a stock rom you need to have a custom rom.
[CDMA/GSM BASSMOD][SENSE3.6/4.0]v17.20 Xloud,Beats,Srs,EQ Tweaks[02 JULY] - [GSM] EVO 3D Development - RootzWiki
it does work for me! just it'll reboot after a while
Not saying it won't work but, by the sound of it, the random reboots are because you don't have a custom rom.![]()
What recovery are you using?
welp now it crashed and wont turn on, how do you uninstall this
If you have a backup then use that. If not do a complete whip and re-flash the stock rom.
Maybe try a custom rom if you really want that mod.
ive been working on creating my own
Cheers, I'm sure the community would love to see what you have been working on.![]()
its just me altering my rooted stock rom but i honestly dont know what i am doing, i do have the newest anthrax kernal on it too
so midnight rom would work, s-off?Does not work on a stock rom you need to have a custom rom.
The op goes on to say this.
So, I'm guessing it won't work.
