Root Reboot error with Titanium Backup
axpkl
I just rooted my phone and download Titanium Pro, apparently it is able to remove system apps.
However when I opened it and clicked on a system app to uninstall, my phone reboots. Any idea why?
You can only uninstall system apps with the phone running if you are S-off. Try freezing them instead with titanium and they'll disappear from your app drawer.
It only works for some people. It has to reboot to continue the process outside of the android environment to get around s-off I think.
If the apps are definitely gone, then good but usually they remain.
Other options are:
-Use adb (have a guide to remove system apps but its not that straight forward)
-Like Shauny says, just freeze them (removing system apps doesnt give you more space anyway)
-Flash a custom rom
