I have noticed that if I ever turn my captivate off and then reboot it; it will take anywhere from 3-5 minutes for the Captivate to fully boot and become usable. Prior to then it is unbelievably laggy and if I even try to dial out it freezes.
I moved my 4gb of music from the internal SD card to the external SD card thinking that may make a difference but that did not solve the problem.
Is anyone else experiencing this problem and is there a way to fix it?
It is not even close to the iPhone! There is a HUGE difference: in the "walled garden" you can only use music files from your desktop iTunes, and its the iTunes that does this scanning/tagging thing (and downconverting/downsampling where needed). The lib of desktop iTunes juts gets synched with the iPhone. iPhone does not do anything else. Well it is (pre iP4) still slow comparing to a good Android phone. And iTunes will slow down your desktop. I do not know what I hate more, iTunes or iPhone.
