Help Reboot Infuse Lose Widgets
jsward12
Hi, does any one have this issue? Such widgets as Pandora and live sports are gone upon a reboot and are not available under the widgets menu. I have to reinstall the app to regain access to the widget.:mad:
Yes, a lot of widgets will not appear upon reboot, furthermore they use a lot of battery life. Another pain in the but to me is when I turn the screen brughtness all the way down, it will not stay down. It aleats manages to eek up. Hoping a gingerbread update or any other updates may help. There are other minor glitches I can't think of right now.
The apps that lose their widgets are installed on the SD card, and this makes them dissapear on reboot for some reason. Go into settings>applications and move those apps to the phone. That will fix your issue
