Help reboot problems
just happened again while in navi
only happens to me in navi mode
it went away for a while upon clearing thr data and cache for the maps app
anyone else with a similar issue or fix?
most likely an app you downloaded, as most all are buggy with ICS at this point.
you don't have to hard reset, but you can try eliminating all apps, and if it still persists, then just swap out your phone.
btw, flash player 11.1 caused this same issue on my GN. got rid of it. don't really need it as it only seems to serve seeing annoying ads on websites anyway.
I have the same problems on stock 4.0.2. It doesnt reboot, just shuts off until i turn it back on. Is thos a known issue or an app conflict?
